Results 1 to 2 of 2
Thread: Drain Volume
    In the Trades Hammy's Avatar
    Dec 2011
    Middle TN
    Default Drain Volume
    We are installing body sprays in a shower and I am concerned about the drain capacity. The shower control valve can supply 9 gpm @ 90 psi. The city reports the supply is normally at 65 to 80 psi static pressure. Drain is a 2" pvc line assuming properly installed.
    Hammy
    One drain at 2" should be able to handle it - just don't stand on the drain cover for long! My tub drain is 1.5", and on full-blast, the tub drains faster than the incoming water...a 2" drain is a lot bigger in area/volume. If you're really worried, they do make 3" drains, or you could put two 2" ones in or a linear drain, but ensure the underneath plumbing is big enough, otherwise, it won't make any difference.
  1. pipe volume
    By cariboo17 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-10-2010, 10:47 AM
  2. Pipe Volume
    By tel in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-23-2009, 06:05 AM
  3. Air Volume Control
    By lzenglish in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-05-2009, 09:06 AM
  4. Low Pressure/low volume
    By secrest2032 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-18-2008, 08:41 AM
  5. Low Volume Flush
    By plunging_queen in forum Toilet Forum discussions
    Last Post: 04-04-2006, 01:07 PM
