Thread: Bath Tub Drain
    DIY Junior Member bpags078's Avatar
    Dec 2011
    New Castle PA
    Default Bath Tub Drain
    I am replacing the bath tub in my older house and found a cast iron p trap. The old drain was brass. Can I connect a PVC drain to the cast iron P-trap?
    You can, though sometimes it's easier to cut out the old trap and install a new trap at the same time.
    If YOU can make a connection to it, then go ahead.
    Dec 2011
    New Castle PA
    Thanks for the input. I did a bit more research and found it to be brass p trap and drain that I had removed. I am going to put a PVC drain in and see what happens.
  1. Bath Tub Drain Removal
    By Carob in forum Shower & bathtub Forum & Blog
    Last Post: 05-31-2011, 08:05 PM
  2. Bath tub drain.
    By Frank G in forum Shower & bathtub Forum & Blog
    Last Post: 11-18-2009, 05:23 PM
  3. Bath drain help.
    By Rusio90 in forum Shower & bathtub Forum & Blog
    Last Post: 12-27-2007, 08:34 PM
  4. bath tub drain
    By 2'sto4's in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-08-2007, 02:37 PM
  5. Converting Shower Drain to Bath Drain
    By sm in forum Shower & bathtub Forum & Blog
    Last Post: 03-12-2006, 06:10 PM
