Results 1 to 7 of 7
Thread: Small bathroom DWV
    DIY Senior Member Fubar411's Avatar
    Nov 2007
    St Louis, MO
    Default Small bathroom DWV
    This is my 2nd floor bath. I'm hoping to do the following, but I wasn't sure if this fitting can be used. It is the 90 3x3x2 with the 2 coming in on the corner.Name:  Plumbing.jpg
    All fixtures are within 3 or 4 feet of each other. Thanks!
    Here is a nice link to Bert Polk's plumbing tips
    Sep 2009
    Seattle. WA
    I quote from my copy of the Uniform Plumbing Code: "No ... side inlet quarter bend ... shall be
    used as a drainage fitting ..."
    Nov 2007
    St Louis, MO
    Now where is the fun in that? Do they make WYEs that have a street bend type ending at the base? This is going to be tight.
    Thank you for your reply!
    Nov 2010
    Maine
    Actually, in the vertical position it can indeed be used that way under everybody's code.
    The inlet does NOT have a sweep, which would make it illegal under most codes, and since the shower does NOT have a vent, and it does not make any difference how CLOSE It is to another fixture.
    Nov 2007
    St Louis, MO
    I have a vent for the shower already, sorry it wasn't pictured. So if I WYE between the toilet and the drain it should be ok? Just abandon the 90 with the side inlet?
    -Rob
    Yes, and they DO make street 'Y"s.
  1. Need toilet for very small bathroom
    By Alicia in forum Toilet Forum discussions
    Last Post: 09-11-2011, 02:27 PM
  2. Need advice on small 14" rough-in (Small Bathroom)
    By SpartyRules! in forum Toilet Forum discussions
    Last Post: 08-25-2009, 01:18 PM
  3. DVW design in small bathroom... Need help.
    By GutJob598 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-04-2009, 06:47 AM
  4. Small bathroom
    By badnailer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-26-2008, 03:37 PM
  5. Small bathroom, Big problems
    By tgillson in forum Remodel Forum & Blog
    Last Post: 01-03-2006, 07:48 PM
