Thread: Electric Wire Size for Submersible Pump
    Default Electric Wire Size for Submersible Pump
    I currently have a Franklin J Class Series V Submersible Pump 1HP 15GPM 230 Volt (2 Lead Wires + Grd.) I am using 14/2 Flat Submersible Cooper Wire with ground. The pump is 190' down the well from the surface. I was told that the wire is good for 250'. After building my house the new electric service will be 75' or more from the well at the surface. Therefore, the new length for wire required will be 265'+ (exceeding 250'). Should I go with 12/2 wire from the house to the well in conduit and set a junction box (approx 75') to avoid voltage drop? I do not want to replace the wire in the well if possible. Also, is it bad practice to place the conduit and wire in the same trench with the waterline?
    Thanks in Advance
    Moderator valveman's Avatar
    Mar 2006
    Running #12 to the well head and #14 down the well should be fine. No problem with wire and pipe in the same ditch.
    Thanks, valveman. I have a setup like your picture (cycle stop valve). It works great. I have moved it to the garage. It was set temporarly at the well head during construction.
  1. Submersible Pumps and Wire
    By Gmen2874 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-20-2011, 05:21 PM
  2. Submersible Pump Size
    By lray882 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-15-2011, 08:08 AM
  3. Need advice on submersible pump size. Pleeeease.......
    By Raggare in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-28-2011, 12:15 PM
  4. Submersible well pump wire question?
    By Greg-VA in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-17-2007, 07:15 AM
  5. submersible pump wire
    By tower_man in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-22-2006, 07:19 AM
