Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Rheem 04EAUSR. Igniter doesn't glow.
    DIY Junior Member Rickcusaf's Avatar
    May 2010
    Navarre FL
    Default Rheem 04EAUSR. Igniter doesn't glow.
    I have a Rheem 04EAUSR and when I turn it on and set it to call for heat, the unit starts up and blows air, but it's not hot. When I went to the garage to look at it, the flame wasn't on. I went through the quick check guide on under the panel and after following the steps I've found out that my igniter doesn't glow at all. What is the next step I should take to diagnose the problem?
    That could be a symptom of the control board, or the ignitor, or a wiring failure (assuming it had worked). Look for obvious things like a loose or corroded, or broken wire to the ignitor. Watch the thing through a full cycle to verify it never gets hot. It doesn't stay hot once the system determines it has actually lit the burner. On some, the ignitor is also the flame detector. If it does get hot, when the gas should then come on, if it doesn't detect that it actually got hot because of the flame, rather than applying electricity to make it glow, it will shut the gas off. So, if it does come on, it could be the gas valve is not opening. This again, could be the valve or the controller. If you are comfortable with a meter, you can verify that the parts are getting their proper voltages at the proper time. Also, if this is a closed combustion device, the fan may not have come on and the vacuum switch interlock may be preventing it from going through the proper cycle since it is sensing some problem with the flue.
    May 2010
    Navarre FL
    I ended up replacing the ignitor based on what a local HVAC guy said. It still didn't glow, but when I turned it on this time, the gas started going and didn't shut off. I ended up turning off and unplugging the unit, because the whole house started to smell like gas.
    Mar 2011
    Houston, TX
    Quote Originally Posted by Rickcusaf View Post
    That is not good at All, I would check the CAD eye.
    Gas is no playing mater...
    May 2010
    Navarre FL
    Where would that be located so I can check it? I did some searching and only found stuff about Oil burners?
    Different makes use different methods to determine if the flame has actually ignited. Sometimes it's a little probe, sometimes it's the dual purpose ignitor/sensor, sometimes it's a photo sensor. Somewhere in your documentation it will have a theory of operation, and describe what you have. Then, either in that manual or on the block diagram often on an inside panel, it will show the interlock, and operational wiring diagram. Unless you deal with wiring diagrams often, they can be confusing, but if you take your time, you can usually figure it out. Whatever your system uses, it must either be in the flame or be able to see the flame.
    May 2010
    Navarre FL
    Would that cause the hot surface ignitor to not glow though? Right now the ignitor is still not glowing.
    Mar 2011
    Houston, TX
    Are You able to read an error code, Looking at the LEDs on the control board ?
    Dec 2009
    northfork, california
    You are definitely going to spring for the HVAC guy, or up your homeowners insurance and take a long vacation.
    Mar 2011
    Houston, TX
    You are definitely going to spring for the HVAC guy.
    That may not be a bad Idea.
    After looking at the service manual for that unit, It looks like it could be a Air Flow sensor, Shutting it down.
    If the old ignitor was bad, and broke and shorted to ground, It may have blown the fuse.
    The three LEDs on the control board should help to troubleshoot the simple problems.
    A service tech may be worth the cost, For safety reasons.
    Dec 2009
    a bad air flow sensor will NEVER let gas flow. Just changed a few. Probably the main board. VERY rare for gas to flow with a igniter hot and the exhaust inducer running. Only chance would be a out of alignment hot igniter, and bad flame sensor.
    Mar 2011
    Houston, TX
    That is True, The gas valve should never open.
    Not sure why there would be a gas smell. That made no sense.
    If the air does not flow the igniter SHOULD never come on either, according to the manual.
    Could be the control board is bad.
    May 2010
    Navarre FL
    Sorry for the delay in replying. The main board has three lights. The Power and Ok lights are on, but the Flame light isn't. Nothing flashes nor do I see any noticeable warning. I'd love to spring for the HVAC guy, but my wife lost her job early December and money is super tight right now. It sucks, because it's starting to dip into the 20s where I live.
    Plumber jimbo's Avatar
    Hate to sound like the grim reaper, but money will be tighter if you have to pay for a funeral. This is just not the type of problem that can be fixed by poking around and changing parts on a whim. If filling the house with a gas smell did not scare the crap out of you, well...I see a new reality show in your future.
    May 2010
    Navarre FL
    It did, but there is no money for an HVAC guy right now. They charge $75 an hour here with a minimum of one hour charged. It hasn't smelled like gas since though. When it happened the first time it was right after I had changed the ignitor and the slow-blow fuse. How much are the control boards and where would I be able to find one if it does happen to be that?
  1. Takagi tk3 flash igniter woes
    By HANK WHITE in forum Tankless Water Heater Forum
    Last Post: 03-10-2010, 01:58 PM
  2. Ruud vs Rheem
    By S30trbo in forum Water Heater Forum, Tanks
    Last Post: 01-27-2010, 08:04 AM
  3. RIP 21 y.o. Rheem. What's next?
    By pmoe in forum Water Heater Forum, Tanks
    Last Post: 09-16-2009, 01:33 PM
  4. Rheem
    By cwhyu2 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-11-2007, 07:23 PM
  5. Rheem Richmond Toilet
    By opalomarez in forum Toilet Forum discussions
    Last Post: 12-04-2006, 10:37 AM
