Results 1 to 8 of 8
Thread: Dual AO Smith 50 gal Vented Gas Installation - Options?
    DIY Member stephenson's Avatar
    Oct 2011
    Northern Virginia
    Default Dual AO Smith 50 gal Vented Gas Installation - Options?
    Assisting neighbor - large house (about 6000 SF) ... has two, 10 year old AO Smith 50 gallon natural gas "Energy Saver" (model FPSH 50 236) tanks run in series ...both power vented. One water casing just failed.
    I'm not convinced the dual system is the best solution ... options:
    1. Replace the one unit
    2. Replace both units and maintain the stepped heating approach
    3. Replace both 50 gallon with one 75 gallon
    What makes sense? If option 3 best bet, which AO Smith (easier sourcing) unit is best application - homeowner will be in house for about 3-5 years.
    Oct 2011
    Northern Virginia
    Did I ask in the wrong sub-forum?
    Any opinions?
    Thanks!!
    Jan 2008
    The first question is how much hot water do they need? If they have a big whirlpool tub or 4 people taking consecutive showers, then they need that and maybe more. Depending on the purity of the water there, replacing both with a tankless might be a better approach.
    Plumber jimbo's Avatar
    You would need multiples or a monster tankless to provide hot water for a 6000 sq ft house with presumably 4 to 6 bathrooms, 2 kitchens and 2 laundries!
    Feb 2005
    Default install a rheem
    tear them both out and install a Rheem Pro 75 gallon gas water heater
    it will do the same work load .... turned up on mid range.....
    you probably will save a few hundred on the gas bill per year and the 75 becsue you are heating less water and less space exposed to ambient air and the heat going out of the chimmny
    the 75 will do the exact same job that the 2 50s
    will do becasue they never will draw properly anyway
    that is the easy way... and if it dont work,
    then just throw in a 40 gallon gas in series with the 75.......
    Oct 2011
    Northern Virginia
    Thanks to all - she opted for the 75 gallon AO Smith replacement for the stepped 50 gallon tanks ... had plenty of space so no issue either way. The 75 gallon solution specs out with plenty of initial output with pretty fast regen. Power vented via 3" PVC per installation instructions - the 50s used 2" so that was a bit of a change and a couple of hours. If there are any issues, will status.
    DIY Senior Member Chad Schloss's Avatar
    Jun 2010
    USA
    why does everyone need that many water heaters? we have one rheem 40 gal powervent. 3 bathrooms, two laundries, two kitchens 4 bedrooms. two people can shower at once. 3rd can shower after and still have enough water for a 10 min shower. maybe i just don't understand...
    In the Trades mtcummins's Avatar
    Jun 2010
    Pittsburgh PA
    Quote Originally Posted by Chad Schloss View Post
    Yeah, I don't really get it either... I have an AO Smith 50 gallon 76,000 btu powervent that feeds 2.5 bathrooms, kitchen, laundry, and heats the whole house through the radiant floors. I've never run out of hot water.
  1. Waste Overflow options & installation
    By DavidTu in forum Shower & bathtub Forum & Blog
    Last Post: 06-18-2011, 07:09 PM
  2. Question on dual direction clean-out installation....
    By tototalitarian in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-30-2011, 12:25 PM
  3. Question about dual flush toilet installation
    By cflushing2 in forum Toilet Forum discussions
    Last Post: 06-20-2010, 03:56 PM
  4. Dual Shower Head Installation - Moentrol?
    By philgristle in forum Shower & bathtub Forum & Blog
    Last Post: 07-23-2007, 02:14 PM
  5. Dual Dishwasher Installation
    By Dave Meers in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-05-2005, 02:24 PM
