Thread: Shower and hand held 3/4 valve
    DIY Junior Member scooterbase 001's Avatar
    Dec 2011
    Santa Clarita Ca.
    Default Shower and hand held 3/4 valve
    Will a 3/4 inch valve with 8 inch shower head and hand held work if I only have 1/2 inch pipe to it or should I run 3/4 all the way to the valve?
    What is the gpm rating of each, and will they ever both be on at the same time?
    Dec 2011
    Santa Clarita Ca.
    I'm not sure what the gpm is, but it's an exterior valve with a n 8 inch rain head and all 3/4 piping from valve up to the head, I would think this would need a good volume of water to be strong enough.
    Federal regulations restrict any single showerhead to 2.5gpm (this is measured at a specific pressure). So, if you only have two possible on at one time, a 1/2" line should be okay. If you want to add stuff like body sprays, or an additional head, it would not. If your house pressure is marginal, no supply will produce your desired effects. Don't expect high pressure out of a rainhead...it isn't very forceful.
  1. I just need a really good shower/hand held.
    By astralfarmer in forum Shower & bathtub Forum & Blog
    Last Post: 09-01-2011, 06:20 AM
  2. hand held shower unit
    By TacomaJake in forum Shower & bathtub Forum & Blog
    Last Post: 03-02-2011, 05:12 PM
  3. Hand held Shower recommendation?
    By ron350 in forum Shower & bathtub Forum & Blog
    Last Post: 09-15-2007, 07:52 PM
  4. Hand held shower only placement
    By Zubini in forum Shower & bathtub Forum & Blog
    Last Post: 04-12-2007, 11:33 PM
  5. Hand-Held Shower Head
    By lammr in forum Shower & bathtub Forum & Blog
    Last Post: 05-02-2006, 07:04 AM
