Results 1 to 9 of 9
Thread: Can I roll a Wye to 45 degrees?
    DIY Junior Member Jeepnick's Avatar
    Nov 2011
    Phoenix, AZ
    Default Can I roll a Wye to 45 degrees?
    Phoenix AZ here (UPC).
    My main 3" drain line is quite deep. To tie the rest of the fixtures into the horizontal main, can I roll a Y up 45 degrees to make the other lines more shallow?
    Alternatively (or in addition to) can I use a 45 to make steep depth change and then level off before entering the Wye?
    Jan 2008
    Yes. Ideally the inlet of a wye will be anywhere from right on top to 45 degrees to either side of the top. Given proper pitch, it can be rolled all the way down to 90 degrees from the top, but that is usually avoided.
    Nov 2010
    Maine
    short of rolling it upside down you can pretty much do anything you want with a wye. Cacher's explanation is good
    quote; Ideally the inlet of a wye will be anywhere from right on top to 45 degrees to either side of the top.
    There is absolutely NOTHING wrong with laying a "Y" on its side, therefore it can be rotated 180 degrees from one side to the other. HOWEVER, depending on which direction you will be going from the "Y" will determine what fittings to use because a 45 elbow will ONLY straighten it out parallel to the pipe if the "Y" is NOT on its side or perfectly vertical.
    Nov 2011
    Phoenix, AZ
    Thanks for the responses! So now that we've established that a Y can be rotated 180 degrees, what about a 45 coming off of it? If I want to roll a Y up to 45 degrees, then put a 45 off of it going off to the side (to attached to a horizontal drain which will empty into the main) can I do that or does the code say no? Or is it a bad practice? Please see attached picture for reference:
    Nov 2010
    Maine
    If it makes the angle you can most certainly go right ahead
    Nov 2011
    Phoenix, AZ
    If it makes the angle... Meaning, if it makes the angle I need? Or if it makes a specific angle?
    Feb 2011
    NW Ontario, Canada
    I would think you need a specific angle so they would be one and the same.
    The dynamics mean that if you want to go 90 degrees to the side the "Y" MUST be on its side. IF you want to go parallel to the main line, but at a higher elevation, it MUST be on its back. Any other angle between parallel and 90 degrees requires that the Y and 45 be "rotated" at specific angles to make the turn. IF the Y is on a "true" 45, then a 60 degree bend, (and they do NOT come in street pattern), will make a "perfect" 90 degree angle from the main at the higher elevation.
  1. Dishwasher does not roll-out
    By michael k in forum Remodel Forum & Blog
    Last Post: 04-11-2011, 08:16 AM
  2. Dishwasher does not roll-out
    By michael k in forum Plumbing Forum Discussion & Blog
    Last Post: 04-10-2011, 07:27 AM
  3. Roll-in shower
    By photogal in forum Shower & bathtub Forum & Blog
    Last Post: 01-04-2007, 07:24 AM
  4. Toilet in Roll-in Shower
    By ette in forum Toilet Forum discussions
    Last Post: 10-26-2005, 01:19 AM
  5. Toilet in Roll-in Shower
    By ette in forum Shower & bathtub Forum & Blog
    Last Post: 10-24-2005, 10:35 AM
