Thread: Why am I getting no water whatsoever from all of my hot water faucets in the house?
    DIY Junior Member jennymaxgirl's Avatar
    Nov 2011
    British Columbia
    Default Why am I getting no water whatsoever from all of my hot water faucets in the house?
    From time to time, I will turn on a faucet in my house and there will be no water coming from the hot water faucet. It will run a very small amount of cold water and then cease to flow any water whatsoever. I usually leave the hot water faucet on with no running water, and eventually there is a loud 'kicking-in' noise and then it will begin to flow water at full force, warm water that turns hot. It has been going on for a couple of years and hasn't caused any leaks or damage yet, but I might be selling our house and would like to figure our this frustrating problem before we go.
    Anyone have any insight?
    Many thanks,
    Jennifer
    Plumber jimbo's Avatar
    I would investigate...probably just replace....the shut-off valve for cold water INTO the water heater. If that doesn't fix it...you may need Dick Tracy.
    Do you have city water or a well?
    Sometimes the water heater will have check valves built into the top connections.
    Those can fail.
  1. Hot water in shower not turning on, all other faucets have hot and cold water
    By redrover in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-08-2011, 07:20 AM
  2. No water to faucets
    By rockzo6 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-28-2009, 06:59 AM
  3. House water turned off for 3 hours, house plumbing out of whack - Air in system?
    By jluksic in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-14-2007, 05:43 AM
  4. Pulsing when faucets turned on in new house
    By boaterbob in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-21-2007, 01:20 PM
  5. Rusty water in toilet & out of hot water faucets
    By lydicfamily@yahoo.com in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-11-2006, 09:16 AM
