Results 1 to 2 of 2
Thread: Venting Question
    DIY Junior Member ztekdesign's Avatar
    Nov 2011
    Wisconsin
    Default Venting Question
    I am adding a bathroom to my basement. I am using a Saniflo system with maceration pump. A vent is required from the pump, sink and shower. Problem is I have no place to tap into the roof vent that feeds the plumbing upstairs. Can this vent be ran to an outside wall? Does it have to vent through the roof?
    Jan 2008
    WI Plumbing code does not allow venting through a side wall unless you get a waiver, which is unheard of to my knowledge.
    I've never seen a house that could not have a vent run from the basement through the roof. It is an easy job in a single story home, and only a little more challenging in a two-story depending on the layout.
  1. Venting question
    By ML in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-12-2010, 10:08 AM
  2. venting question...
    By jeffreypca in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-16-2009, 10:22 AM
  3. Question on venting
    By NickM in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-12-2009, 06:17 AM
  4. Venting question....
    By Randyj in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-21-2007, 09:41 AM
  5. Venting question
    By Allie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-30-2005, 05:30 AM
