Results 1 to 6 of 6
Thread: Whole house filter with jet pump and pressure tank
    DIY Junior Member mbinetti's Avatar
    Nov 2011
    BDA, NJ
    Default Whole house filter with jet pump and pressure tank
    Hello everyone,
    I need a little advice. I apologize if this subject has already been addressed. I have 1.0HP Myers jet pump and I believe a 14 gallon pressure tank. My pressure switch was originally 40/60. Anyway, about 7 months ago I installed a whole house filter (AP907) after the pressure tank. I think it is starting to clog up because I can no longer have two draws on the system at the same time. If I am taking a shower, no one can run the kitchen sink. I initially tried increasing pressure from the switch, its set at about 45/63 now but still the same problem. I can replace the filter but its supposed to last a year. I am thinking of raising the pressure switch again to 50/65 but wonder what other options I may have.
    Does anybody have any advice to increase my pressure? thanks in advance.
    Feb 2011
    NW Ontario, Canada
    Change the filter and/or install two in parallel.
    Nov 2010
    Maine
    I hate whole house filters but if you must, you must also maintain them. Change the element and presto......life is better, for awhile anyway
    Nov 2011
    BDA, NJ
    I know what you mean about the WHF, but it is necessary. I rather not change the filter so soon. So would a CSV be of any use? Any other constant pressure solution out there? Should I be worried about the 65-70 pressure setting? I should also note it is a 3/4 HP not a 1 HP jet pump. Any more advice would be helpful.
    Feb 2011
    NW Ontario, Canada
    A CSV would do nothing for loss of volume which is what the WHF is causing. Either get a bigger filter that can provide more GPM or twin two in parallel.
    Nov 2010
    Maine
    No, change the damn filter, it's plugged up. Would you leave a plugged oil or fuel filter in your car?
  1. 3M recommends pressure tank size for their CBF100 carbon filter
    By hcw3 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-16-2012, 08:55 PM
  2. Use Chlorine (Charcoal) filter in Whole House Sediment Filter Housing ??
    By kstuart in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-03-2011, 02:04 PM
  3. Well gpm/pressure/tanks/softner/filter/distance from house questions.
    By maxfischersweet in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-11-2010, 10:41 PM
  4. Water Pressure Booter Pump w/softener and whole house filter
    By dsteph3 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-13-2010, 06:12 AM
  5. Pressure at tank is great, in house is low unless pump is running
    By greghughes in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-16-2008, 09:06 AM
