Results 1 to 5 of 5
Thread: Monoflow vs. Strait loop
    DIY Junior Member Peter57's Avatar
    Nov 2011
    Default Monoflow vs. Strait loop
    Hi all:
    I'm replacing a 60 year old copper/monoflow system with PEX, and am considering a strait through loop. I could use some advice.
    The heating is for the first floor, 1 zone, about 750 sq. ft. I plan to branch off from a common 1 inch PEX feed into two 3/4 inch loops of approx. same size. The baseboard is Hi output slantfin (80) with 3/4 inch copper. Strait thru is so much simpler than monoflow, but are their disadvantages with strait thru? Why was monoflow even used in the first place? Am I doing the right thing??
    Also, do I need bleeders in a strait thru loop? (I will put shutoff valves in each zone)
    Regards, Peter
    Last edited by Peter57; 11-27-2011 at 05:38 PM. Reason: added last question on bleeders
    Mar 2011
    Long Island, NY
    With monoflow Tees, you can shut off each baseboard radiator without shutting off the flow for the entire loop. If you have no need to be able to shut off individual radiators in the loop, I don't know if you'd need those tees. I never worked with PEX, but I've read that the effective sizes are different than those of copper because of the wall thickness, so you'd need to go up a size to get the same flow rating.
    Nov 2010
    Maine
    Go with loop piping, there is way less pump head loss. I would bring each loop back to the boiler manifold rather than split 1" pex.
    quote; Go with loop piping, there is way less pump head loss
    I doubt that that is true because a Mono-Flo system uses a larger main "loop" which creates LESS flow restriction.
    Nov 2011
    Thanx. I don't really need to shut off each baseboard. I've resched the PEX wall thickness and you're right, it is a bit smaller.
  1. Monoflow loop - moving a convector - couple of q's
    By scott_r in forum HVAC Heating & Cooling
    Last Post: 08-04-2009, 09:26 AM
  2. monoflow "T"s in a series loop?
    By sibi1972 in forum HVAC Heating & Cooling
    Last Post: 10-04-2008, 08:52 PM
  3. MonoFlow and Pex
    By rockycmt in forum HVAC Heating & Cooling
    Last Post: 10-03-2008, 04:12 AM
  4. adding a loop in a monoflow system
    By randilo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-29-2007, 05:07 AM
  5. Monoflow to Series loop conversion
    By mfdyno in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-31-2005, 07:27 PM
