OK if I have correctly followed your advice, this is what I need?
The last question is ABS or PVC...
Actually, I see you replied as I was creating this post, I wasn't even thinking about that one. Thank you.
Here is a closer view of that area. Not a big deal I don't think. For a lack of better term, that rubber ring the vent stack is connected into, is that simply a press/friction fit?
So what I am wanting to do here is have the sink on its own drain and the washer on its own drain, correct?
I really appreciate all the help, and, sorry for so many questions. I bought a book tonight hoping I could read up on it and get a better understanding, but it's useless. Might have to return it.
You're on the right track now.
Yes you need to have 2 drain lines, unless you wanted to dump your washing machine into the sink?
I would really prefer not to. I know it's just a laundry/utility room, but I'd like it to have its own drain and maybe even keep the sink from filling up with water!
Is my best option to just replace the drain/waste stack with all PVC from the top below the 90* down to the rubber gasket in the floor there?
If I was you, I would replace almost everything in the picture, what is in the slab cast iron?
You can keep the abs vent portion...
quote;And here I thought that each trap required it's own vent...
Every trap REQUIRES a vent, but the vent can be shared with other traps is that is more convenient. There are MANY ways to revise the drain system so it is "correct", but if you were to purchase the wall mount bracket for that sink so you could elevate it a couple of inches higher, what you have, even though it is "improper", would work, after you unplug the stoppage causing the backup.
OK I don't mean to stir the pot, but just get a better understanding of things. I have had a couple people tell me that since my drains are within 4' of the waste/vent stack, then I do not need additional ventilation? Looking at my diagram with a "WTF are you doing?" face...
Also, more for my understanding, what is the reasoning on where you can and can't use SanTee vs. Wye fittings? What is the difference in function? Thank you.
It has to do with the sweep and not tending to back waste up into the side inlet. On the vertical, a wye inlet would have the vent below the weir of the trap, and thus the trap would siphon.
Basically, you can't put a Tee fitting on its side, so that you have a 90 degree turn, in a drain line. You also should not use a 90 degree elbow on its side in a drain line. What you want for your sink to be proper is a 45 degree turn into a wye fitting, giving a more gentle turn and better flow rate.
Vertically, you do not want waste lines going into a wye, as the vent line comes down too far (below the trap weir, as jimbo said), and you end up with an S-trap. This is where you need a SanTee, which keeps the vent line higher than the trap.
For venting, most of this doesn't apply, but for drain lines, you have to be very cautious which fitting you are using and where.
As for your vent situation, i'm not sure exactly what the code is, but I think that you're ok with the sink drain being between the standpipe and the vent, with both sharing the vent. If the standpipe was between the sink and the main line, you would probably have very poor venting of the sink while the washer was discharging, and this would be more concerning. If you don't mind raising your sink, you could simply cut out the SanTee and replace it with a wye and 45, put in a proper trap, and call it a day, other than cleaning out whatever clog you have going on. Again, i can't say for sure that this will pass code, but it would be very functional. If you want to get into a much bigger project, you could rip it all out and follow the advice above.
It looks like you could also just lower your entire assembly (rather than raising the sink) by cutting the vent line above the main drain tie-in, pull the whole drain assembly out, cut the drain part below the cleanout shorter, put it back in, and extend your vent with a chunk of 2" and 2 sleeves. I'd still fix the sink drain with a wye and proper P trap, but this would solve the height problem with minimal work.
Wow, thanks for taking the time to type all that out.
In the picture above, the sink drain, what is the proper way to come out from the 2" horizontal? A Wye/45 with a cap in the other end? I already purchased a 2" 90 with 1-1/2" adapter for the trap stub-out (I suppose I could have just done 1-1/2" the entire way). Is this going to pose a problem? Probably not optimal, but I don't see it saturating the drain...Basically, you can't put a Tee fitting on its side, so that you have a 90 degree turn, in a drain line. You also should not use a 90 degree elbow on its side in a drain line. What you want for your sink to be proper is a 45 degree turn into a wye fitting, giving a more gentle turn and better flow rate.
I'll re-read all the rest after supper.![]()
Well, that was a hard lesson to find out that vent wasn't entirely 'dry'...up comes 3 rows of flooring + underlayment, and a lot of towels (Translation: Opened up the vent/drain in the basement, used the sink upstairs. Water all over the downstairs.) I tested it a couple days ago, and the drain was definitely coming down the other pipe. Wonder if there is an issue upstairs too. FML. Time for a beer.
Alright, got it all done last night, minus the vent line coming out from the sink drain. I had a few people tell me it was so close to the vertical stack that it wasn't necessary.
But, I screwed up. How badly? I don't know...you can tell me.
I THOUGHT when I was checking the pipes to see if they were drain/vent or just vent, that it was just a vent. Well, I found out the hard way last night when I washed my hands, that it was in fact the drain from the sink upstairs. What a mess to clean up.
Here is where I went wrong. When I had the water draining, I felt the 2 pipes, and I felt what felt like water flowing in the other pipe, and felt the vibration etc.; but felt no vibration in this pipe we are working on. Turns out, that vibration I was feeling is because that other ABS pipe was resting on the copper supply line, and transferring vibrations in that way. Once I pushed up on the other ABS pipe, with the water running, I felt nothing in it. So, I don't know what the heck is going on. I will take a couple more pictures and hopefully you can help me understand.
Based on that information, is my 'vent' completely wrong now?
Also, even with the sink T above the washer T, when I put the hose in the washer stack, it backs up and then fills up the sink. I must have a good clog below the slab somewhere. My little 25' snake didn't catch anything though. Might need to call someone in for that?
The pipe coming down from the upstairs is a drain, and it cannot be used as a vent.
You need a new vent if you plan on complying with any plumbing code.
In addition, the drain pipe itself is likely too small to meet code seeing that there are additional fixtures connected to it.
Isn't plumbing fun?
quote; You also should not use a 90 degree elbow on its side in a drain line.
Interesting because almost EVERY DWV has a least ONE elbow on its side, and most have SEVERAL. Being "close" to a vent is NOT the definition of whether it is proper or not. Just because your refrigerator is next to the kitchen table will NOT keep it from going sour. In fact, the washer flowing past the sink drain is NOT the ideal configuration, and is FAR from ideal, but as I mentioned previously, it WILL work, but it is NOT how I would do it. The prohibition against a sanitary tee in a horizontal line has to do with the limited "sweep" the branch open has, compared to "Y"s and combos.
No, not fun, not fun at all! :-) Just so you guys understand I'm not trying to add anything new or fancy here, just trying to properly 'fix' was was done previously. It's also a very slow drain still. Might have to call out one of you pros to do a real job on cleaning out all my drains/traps/pipes whatever.
I'm going to post a couple pictures to see if you can hopefully help me figure out what I have going on here. Any ideas?
This is below the bathroom sink upstairs. The drain is obviously the drain, Line B is unknown. There is something protruding up into the attic above this area and 90'd over to the main stack vent and through the roof though.
Same 2 lines. Line labeled 'drain' is what is turning down the wall and is the same pipe that the washer/sink are draining into. Line B goes into the adjacent room.
Line B coming in. Not connected to anything, just runs straight into a soil pipe and down into the concrete slab.
Another shot of the big mess in the adjacent room. I'd like to tuck it up as closely to the joists as possible when I refinish the basement so I don't have to build a huge bulkhead around all that mess.
