Results 1 to 2 of 2
Thread: bypass tankless in smith water boiler
    DIY Junior Member
    Nov 2011
    massachusetts
    Default bypass tankless in smith water boiler
    I've read several different opinions on capping off the tankless coil. I don't want to run in series with the tankless on my smith series 8 boiler. just bypass it with an electric water heater.
    we have extremely low electric rates
    There is a 4007a Aquastat that the thermostat splices into then runs to a carlin 40200-02. I really don't understand about the aquastat the manual says it is low limit. but there is no high limit that i can see but i have 2 more boilers (3 family house) that uses the same setup. Do i set the temp at 140 or 190?
    I do know most of the workings of the boiler just not the aquastat. plus information on capping the coil. not removing it. Thank you very much
    DIY Junior Member
    Nov 2011
    massachusetts
    Default I need to do this.. This morning
    I met an old time plumber and got my answers elsewhere
  1. Replies: 1
    Last Post: 11-19-2011, 03:40 AM
  2. Replies: 0
    Last Post: 10-31-2011, 07:35 PM
  3. Install tankless water heater using coil in boiler
    By Nals in forum Tankless Water Heater Forum
    Last Post: 06-16-2009, 12:30 PM
  4. Boiler bypass using mixing valve??
    By HandyManDan in forum HVAC Heating & Cooling
    Last Post: 02-21-2009, 01:21 PM
  5. Straight Talk About "On-Demand Tankless Water Heaters by A.O. Smith
    By SewerRatz in forum Tankless Water Heater Forum
    Last Post: 02-13-2009, 05:05 PM
