Remove the checkvalve in the house unless it is part of a snifter.
I have a water sppicket at well head, pump and tank is at the house, check valve in well at one at house. If I want to run water at well spicket I need to run at house and get pump to kick on first right? Just wanted to ask before I tried and didin't want to mess anything up, thanks.
Yes, the way it's presently connected that's what you have to do!
LLigetfa said it best!
Porky Cutter, MGWC
(Master Ground Water Consultant)
