Results 1 to 2 of 2
Thread: size vent
    DIY Junior Member el pacha's Avatar
    Nov 2011
    New York
    Default size vent
    i got 2 problems,
    1. how much should be the minimum diameter of a circuit vent totaling 55 feet developed length and serving a horizontal drain branch, handling 120 dfu's?
    2.a vent stack handling 25 dfu's with a developed lenght of 35 feet, how much should be the minimum of diameter?
    1. If you do not already know the answers to these two questions, you may be doing a job you are not qualified for.
    2. Your blueprint, which you used to get your permit, should have these sizes specified on its plumbing diagram.
  1. Vent size?
    By rick.a in forum IPC Plumbing Code Questions
    Last Post: 06-11-2011, 09:55 AM
  2. Vent size?
    By rick.a in forum UPC Plumbing Code Questions
    Last Post: 06-06-2011, 02:09 PM
  3. Vent size ?
    By Mudball in forum Plumbing Forum Discussion & Blog
    Last Post: 09-15-2009, 01:55 AM
  4. reducing vent size
    By straightjacket in forum Plumbing Forum Discussion & Blog
    Last Post: 09-03-2007, 07:50 AM
  5. Vent size
    By damorej in forum Plumbing Forum Discussion & Blog
    Last Post: 02-11-2005, 04:33 AM
