Thread: Toto Ultramax Handle Broken?
    DIY Senior Member lordmoosh's Avatar
    Aug 2007
    USA
    Default Toto Ultramax Handle Broken?
    Hello all,
    Recently my Toto Ultramax toilet has had a loose handle. Today I heard the water running and noticed the handle was down causing the flapper to stay open. I called Toto to get a replacement handle under warranty but the guy told me that the 5 year warranty is for the china and 1 year for the parts. I purchased the toilet August 2007. Does this sound correct?
    At any rate he told me to see if the screw inside of the handle is loose so I took the handle off of the toilet and noticed the plastic inside of the handle had a piece broken off from it but the screw was tight. I would think I could replace the plastic piece but I do not have time to waste as this is our only toilet in the house. Could you guys tell me how much does part usually runs and where I should buy it (Toto or some 3rd party?). Thank you!
    I think you can take the advice given by Toto CS as gospel. Here's what I'd do if this was my potty. First, I'd rig a cord from the flapper chain to the top of the tank so I could flush manually while getting the need repair part. This is not a classy or permanent fix, just something to get by. Next, I would either find a new handle locally or order one from Toto. I really don't know if a generic handle would fit or not, but it would be easy to find out. Just take the broken one with you and go shopping in plumbing shops.
    A generic made for the Eljer side mount may work.
    Or you can pick up the Toto handle for around $20
  1. Replies: 5
    Last Post: 09-09-2011, 04:04 AM
  2. Replies: 3
    Last Post: 06-14-2011, 07:22 AM
  3. broken handle on main shutoff
    By johnny-canuck in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-29-2010, 05:34 AM
  4. Shower handle stem broken.
    By Marksavage in forum Shower & bathtub Forum & Blog
    Last Post: 03-26-2010, 01:36 PM
  5. broken shower faucet handle is stuck
    By redleader in forum Shower & bathtub Forum & Blog
    Last Post: 02-19-2008, 01:40 AM
