Results 1 to 2 of 2
Thread: Noisy Taco 007 Circulator
    DIY Junior Member greekguy7's Avatar
    Jul 2005
    Illinois
    Default Noisy Taco 007 Circulator
    A couple weeks ago I bought a Taco 007 pump and installed it the other day. The problem is that after I purged the zone properly and powered it up, I did get heat in the zone but the pump is making a bad noise. The boiler pressure is fine, the pump is not mounted upside down or sideways and all the zones work fine. I have a couple other of these same pumps in other zones on this same system and you can barely hear them.
    Have you seen many of these pumps being defective out of the box before? Any ideas or suggestions?
    Nov 2010
    Maine
    yes, return it
  1. Cause of Taco wate circulator noise?
    By goshenplumber in forum Boiler Forum
    Last Post: 10-31-2011, 09:21 AM
  2. Taco 006 BC4 Circulator pump running 24/7?
    By scottall in forum Water Heater Forum, Tanks
    Last Post: 03-18-2010, 07:42 AM
  3. taco circulator wiring
    By litemine in forum Plumbing Forum Discussion & Blog
    Last Post: 11-25-2007, 03:28 PM
  4. Taco Flo check circulator pump
    By MarkHash in forum HVAC Heating & Cooling
    Last Post: 10-04-2007, 08:23 PM
  5. Taco 003 Hot Water Circulator Pump Runs Hot!
    By gplumb in forum Plumbing Forum Discussion & Blog
    Last Post: 03-24-2007, 05:30 PM
