Thread: Questions about wyes in new bathroom drain configuration
    DIY Junior Member CPinCT's Avatar
    Apr 2010
    CT
    Default Questions about wyes in new bathroom drain configuration
    The picture shows my plan for the drains for a new bathroom in an addition. My questions are concerning the wyes. Can the one for the toilet be a combo? Can the other two lay on their side or do they need to be rolled up 45 degrees? Should one for the sink be in the middle of the other two?
    Apr 2010
    CT
    Any help here would be greatly appreciated. Thanks.
    Aug 2009
    South*East
    Looks OK why change it? Y's are always better then combo's if you have the room.
    John
    quote; Y's are always better then combo's if you have the room
    Now why would you say that? If you need to connect at a 45 degree angle, then you NEED a Y, but if the connection is at a 90 degree angle, then a combo is EXACTLY the same as a Y and 1/8 bend. If you roll a Y up on an angle then you have "destroyed" the 45 degree angle and have to compensate with another fitting of some kind. WHERE the sink, or anything else, connects is usually immaterial, assuming the rest of the system is done correctly, but it could depend on the exact configuration of the rest of the piping.
  1. Has anyone seen a drain configuration like this ?
    By Jeff Nolan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-30-2007, 06:57 AM
  2. Unusual Bathroom Vanity Configuration
    By gtfisher in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-09-2006, 10:24 AM
  3. Question About Flat Wyes
    By sjsmithjr in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-02-2006, 01:56 PM
  4. Upstairs bathroom; drain questions
    By baghuan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-30-2005, 07:22 AM
  5. Drain Configuration for 2 sinks
    By Rob in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-01-2004, 04:37 AM
