Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Thread: Boiler getting overpressurized -- reaches 30 PSI and PRV releases water
  1. #16
    Your method seems right, I didn't check the math. Sounds like the tank you have is sufficient.
    Unless you've got some trapped air in the lines (air will expand MUCH more than the water with temp changes), and you've ruled out the autofill valve and heat exchanger in the indirect, I can't think of anything else. Try to purge the lines and double-check your air extraction device for proper operation.
  2. #17
    Turn off the autofill for a week and see if the pressure stabilizes. If it does, you've found the problem.
  1. How much water in the boiler
    By Rob C in forum Boiler Forum
    Last Post: 10-21-2009, 09:52 AM
  2. Shower head releases in middle of night
    By mrick in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-17-2008, 03:33 AM
  3. Hot Water Boiler Value
    By ttw4454 in forum HVAC Heating & Cooling
    Last Post: 06-25-2007, 09:04 AM
  4. Pressure valve releases in freezing weather
    By jmericle1 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-10-2007, 06:41 AM
  5. Back boiler & oil boiler to twin copper cylinder
    By sheen in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-07-2006, 04:34 AM
