Well, did you actually replace the rubber flapper valve? I see one thing that isn't right...there should not be a metal washer on the tank/bowl mounting screws...the head needs to just have a rubber washer underneath it or eventually, it will leak. It's possible, but unlikely at this point (would have likely noticed it when new, not after awhile), on the bottom of the tank, the big nut that holds the overflow, flapper valve seat assembly in place.
