A picture and model number would help, but generally, often underneath the trim, there's a nut you must loosen to remove a stem. Make sure that the water to the valve is off before you try to remove it. If the stem is worn (it might just be the packing), you may also want to remove and replace the valve seat. This does take a special (inexpensive) tool.
