Thread: Standyne shower single water control leak
    DIY Junior Member BrianGB's Avatar
    Nov 2011
    Galloway, NJ
    Question Standyne shower single water control leak
    This faucet has a continual leak. How can I remove the brass stem? Do I need a special tool to remove that stem? I can remove the pin but can't get the stem valve out. Thanks for any tips!
    A picture and model number would help, but generally, often underneath the trim, there's a nut you must loosen to remove a stem. Make sure that the water to the valve is off before you try to remove it. If the stem is worn (it might just be the packing), you may also want to remove and replace the valve seat. This does take a special (inexpensive) tool.
    Nov 2011
    Galloway, NJ
    Is the tool you need is like a puller that you attach to the end of the valve stem to remove the stem .Then do you need another tool to remove the seat. The make is a Stanadyne-there is no model number that I can find.
    Typically, and I don't know on this one specifically, you don't use a handle puller, it's just a plain wrench. A valve seat wrench is a simple tapered (square) rod that fits into the middle of the seat (where the water comes out). Now, to remove the handle not the stem), you might need a handle puller. Again, a picture would help.
  1. Single shower valves have no volume control??
    By bleu_is_bleu in forum Plumbing Forum Discussion & Blog
    Last Post: 09-22-2011, 06:12 AM
  2. moen single shower control
    By gfe76 in forum Plumbing Forum Discussion & Blog
    Last Post: 01-06-2009, 07:22 AM
  3. Replies: 1
    Last Post: 10-28-2007, 04:01 PM
  4. Moen single control bathtub/shower faucet leak
    By gmrsich in forum Shower & bathtub Forum & Blog
    Last Post: 04-15-2007, 10:13 AM
  5. delta single handle shower control
    By dmetz in forum Plumbing Forum Discussion & Blog
    Last Post: 03-18-2006, 01:33 PM
