Hello, I have a Grohe Grohmix 19229 shower faucet with a thermostatic valve 34419. It was initially installed in 1996. Gradually, over the past few years the handle became harder and harder to turn. As of the other day it became loose and spins but does not change the water temperature - you can feel that there is no grab. I've taken it apart and cleaned the pieces with a vinegar solution. I cannot remove the cartridge – it is stuck. The shower has no leaks or drips. The pressure is fine. There was no moisture inside the wall when I took the faucet apart.
I checked that the pieces I could remove were intact the teeth on the stop ring are intact no threads stripped, no cracks. When I put the faucet back together the same thing happened and the handle is loose and doesn't change the water temperature. I tightened the handle screw but it becomes loose again after a few turns.
My question is, is this a cartridge issue? Or do I just need to replace the other parts like the plastic thermostat handle?
