You do want a vapor barrier and bring it down lapped over the tub's tiling flange. You only need the cbu up to the height of the showerhead, but you can go further. To keep the cbu from bowing out, you can shim the studs, notch the studs (and recess the tub's flange so it is flush with the studs), or stop it slightly above the flange and make sure the tile is more than half supported on the cbu. The tile should not be touching the tub, but a slight gap that is caulked.
