Results 1 to 15 of 33
Thread: 6 AWG to 100 amp subpanel?
Hybrid View
    DIY Junior Member seattle_steve's Avatar
    Jan 2011
    Seattle, WA
    Default 6 AWG to 100 amp subpanel?
    I'm installing a sub-panel for a new addition. My load calc suggests a 50amp load for the sub-panel. So, I'm planning a 50amp feeder breaker in the main panel with #6 feeder wire to the sub-panel. But, the local retail stores don't carry (Siemens) panels smaller than 100amp. I checked with the local inspector (Seattle) and he said that it's common practice to feed a larger sub-panel (e.g., 100amp) from a smaller main feeder breaker/wire (e.g. 50amp, #6 wire).
    The problem is that the 100amp main breaker in the sub-panel I bought lists a wire gauge range of "4 - 3/0". I assume this means I cannot connect #6 wire to it? I don't want to size up the feeder wire/breaker, so what are my options? Are there 100amp sub-panels that will accept smaller wire? BTW, the inspector mentioned that I might run into this issue, but I didn't really follow his recommended solution. Best I could tell, he was suggesting shimming the wire somehow at the 100amp breaker/connecter. That doesn't seem right to me... Is there some sort of adapter available for this situation?
    Thanks.
    DIY Senior Member Chad Schloss's Avatar
    Jun 2010
    USA
    i just wired the same panel in my garage with 6/3 using the 100a siemens panel. worked for me.
    Electrical Contractor Jim Port's Avatar
    Aug 2009
    Maryland
    I just wired the same panel in my garage with 6/3 using the 100a siemens panel. worked for me.
    Just because it works does not make it ok or a code compliant installation.
    You should splice a short piece of #4 onto the #6 and terminate the #4 on the breaker lugs.
    Jan 2011
    Seattle, WA
    Quote Originally Posted by Jim Port View Post
    Thanks Jim. By "splice" do you mean simply twist-with-wire-nut as you would with smaller gauge splices?
    Steve
    Dec 2009
    northfork, california
    I think you need a panel without a main and infeed thru a 50 amp breaker.
    That would be good, but as long as the wire feeding the subpanel is protected to the size of the wire, it doesn't really matter.
    Jun 2007
    North Carolina
    Quote Originally Posted by seattle_steve View Post
    Thanks Jim. By "splice" do you mean simply twist-with-wire-nut as you would with smaller gauge splices? Steve
    Use a split bolt or a Polaris
    That would be backfed and that is what is being done with the 100 amp breaker
    What Jim said
  1. Question about subpanel
    By wjones4 in forum Electrical Forum discussion & Blog
    Last Post: 07-02-2009, 04:53 PM
  2. New subpanel?
    By Zenman in forum Electrical Forum discussion & Blog
    Last Post: 04-12-2009, 09:58 AM
  3. subpanel
    By HockeyFan in forum Electrical Forum discussion & Blog
    Last Post: 02-18-2008, 11:08 AM
  4. Subpanel
    By benr in forum Electrical Forum discussion & Blog
    Last Post: 09-07-2007, 07:07 PM
  5. 2nd floor subpanel
    By Jed54 in forum Electrical Forum discussion & Blog
    Last Post: 08-10-2007, 09:25 AM
