Results 1 to 2 of 2
Thread: Kerdi and RedGuard?
    DIY Junior Member Jackie G's Avatar
    Nov 2011
    Indiana
    Default Kerdi and RedGuard?
    Hello, I am a new poster and am hoping I can get information regarding waterproofing a shower/tub remodel. I am going to use Hardi Backer and Redguard as a waterproofing membrane. Can I then use the Kerdi gaskets on the water pipe and valve protrusions when using the RedGuard? Is there a better way to waterproof those areas?
    Regards,
    Jackie
    It is rare when those penetrations need special sealing issues. A shower head is so high, the eschution would likely block any issues. The valves typically have a gasket behind them, and if your tilework is decent, will prevent any moisture from doing anything. But, since Redgard is designed to enable thinset to bond to it, and the Kerdi fleece bonds with thinset, it should work.
  1. Kerdi Membrane
    By DanMcD in forum Shower & bathtub Forum & Blog
    Last Post: 02-09-2014, 11:34 AM
  2. Kerdi board
    By kcchiu in forum Remodel Forum & Blog
    Last Post: 10-23-2013, 10:39 PM
  3. Kerdi with Noble
    By crayola32 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-18-2011, 09:54 PM
  4. Kerdi Wicking
    By GCloud in forum Shower & bathtub Forum & Blog
    Last Post: 02-21-2011, 11:49 PM
  5. Kerdi Showers
    By prashster in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-27-2006, 08:50 AM
