Results 1 to 6 of 6
Thread: W/C DFU question
    DIY Junior Member Mr. Larson's Avatar
    Nov 2011
    Everett, WA
    Default W/C DFU question
    So, I have taken my residential test twice now, and I failed! I have done well on everything but the waste and venting portion. I am beginning to believe there is something I'm just not getting, or maybe there is a sneaky trick to the test. Anyways, I would like to know how many 1.6 gravity tank toilets can be put on a 3" drain, (private/public)... and how many flushometer valve toilets can go on a 3" drain, (private/public).
    Aug 2009
    South*East
    I believe the answer to both is two on a horizontal and three on a vertical drain.
    John
    Plumber jimbo's Avatar
    I believe the answer to both is THREE, from table 7-5
    Three toilets, of any kind, on a 3" line. A fourth toilet requires that it be increased to 4" FROM that point on. However, if this is per the IPC then the answer could be anything, depending on the cheapest way to install it.
    Plumber Winslow's Avatar
    Dec 2005
    Hawaii
    three on a horizontal line and 4 on a stack, according to the UPC
    In the Trades mtcummins's Avatar
    Jun 2010
    Pittsburgh PA
    Well I think its 4 and 4.
    Haha, no its not. Just amused that every post was a different answer. Pretty sure that 3 on horizontal 3" line is correct, but I have no idea on a vertical/stack. If I remember right, this horizontal setup would require one 2" vent between the first (furthest from stack) and second toilets, but I could be wrong (pros, please correct me if I am). I don't ever deal with situations like that, all my multiple toilet situations are stacked vertically (we city people build up, not out )
  1. Quick question on glass framed pivoting shower door hardware question
    By watson524 in forum Shower & bathtub Forum & Blog
    Last Post: 02-09-2011, 05:38 PM
  2. Question about Outlets and terminals/push-in(real question, not a troll)
    By cswilson in forum Electrical Forum discussion & Blog
    Last Post: 12-01-2010, 03:56 PM
  3. Route question,Light question
    By solutions in forum Electrical Forum discussion & Blog
    Last Post: 04-01-2008, 08:49 AM
