Results 1 to 2 of 2
Thread: Takagi outdoor propane tankless tk3
    Retired Auto Mechanic HANKSTER's Avatar
    Nov 2011
    Redding, Calif
    Unhappy Takagi outdoor propane tankless tk3
    The *&^%$ takagi tk3 water heater wouldn't start again this morning in redding, ca. The outside
    air temp was 41 degrees, and the infrared thermometer (auto shop tool) said the propane pipe was
    at 31 degrees and the h20 pipe was at 35 degrees. No fire at all, and propane this cold probably
    wont burn well at all, no matter how big the tank or pipes are. I noticed this cold propane
    problem as a young marine in the snow at high altitude on maneuvers. I don't think propane
    has changed much in the ensuing 40 years, so before you crush that *&^%$ tankless unit, get
    or borrow an infrared thermometer and see just how cold the h20 and gas inlets really are!
    I never could light really cold propane. There is probably some special fix i am clueless about.
    Jan 2009
    Temps at high altitude tend to be a heluva lot colder than 31F. Frost on the propane line isn't usually a problem (but with butane it could be.) Don't blame the fuel- they use propane as heating fuel with above-ground tanks in places with design temps in the negative teens, and you BET the tank temps are well below 31F!
    Careful about looking at pipes with infra-red- the emissivity of bare metals can be quite different from the IR thermometer's presumption. It'll read significantly on the low side for any shiny bare metal.
  1. Replies: 1
    Last Post: 11-19-2011, 03:40 AM
  2. Delta Monitor Shower Valves and Takagi tankless heater problems
    By hptulsa in forum Shower & bathtub Forum & Blog
    Last Post: 10-27-2011, 11:56 AM
  3. Water Going Cold with Takagi Tankless
    By monty in forum Tankless Water Heater Forum
    Last Post: 05-28-2010, 11:09 AM
  4. takagi K3 Propane line question
    By jordan69s in forum Tankless Water Heater Forum
    Last Post: 04-14-2009, 12:44 PM
  5. Tankless H2O: Rheem vs. Takagi
    By teamviper in forum Plumbing Forum Discussion & Blog
    Last Post: 02-15-2007, 04:35 AM
