Results 1 to 10 of 10
Thread: Fleck 7000 not softening or consuming salt
Hybrid View
    DIY Junior Member SES's Avatar
    Nov 2011
    TX
    Default Fleck 7000 not softening or consuming salt
    I just purchased a house with a Fleck 7000 system and have lived there for just over 2 months and noticed we have not consumed any salt. Ive manually run several regenerations, confirmed all settings (H-18, all the rest set at default), monitored the system cycle and noticed the water level in the brine tank is just a few inches and does not rise above the metal grid at the bottom of the brine tank or near the float on the check valve. I manually added water and ran regeneration and it consumed salt, and I verified its adding back water, but it looks like Id need to increase the refill time from the default 10 min. to 20+ to get the water level up past the grid. Should I change the refill time, or is something else wrong. Water hardness is 18, Im not sure of the size of the system; (its a chrome cylinder about 4 ft. tall). Were a family of four and have a pool, so were consuming allot of water.
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    It sounds to me that the air check is below the grid plate. I've seen this happen many times. The air check should be centered of the grid plate. If it's not the bottom, the fill time will not allow enough water to come above the grid. Measure the distant from the bottom of the brine tank to the bottom of the elbow of the brine line. Then measure the from the bottom of the air check to the bottom of the elbow. Bet they are real close. Should be about 4" difference.
    Nov 2011
    TX
    I'm new to water softeners so I'll need some clarification.
    In the brine tank I have a large plastic tube and inside that is the filler tube and a check valve assembly triggered by two floats. (A small float at the bottom that appears to stop the system from sucking air into the system once the water drops to a certine level, than a overflow shut off triggered from a larger flow attached midway up the tube). Its not the “safety brine valve” and “aircheck assembly” shown in the manual.
    The distance bettween the upper shut off float and the bottom (what I’m assuming is the air check assembly) is maybe a foot. The air check is just off the bottom of the brine tank several inches (maybe 6”) below the grid.
    Nov 2010
    Ocala, Florida
    Can you remove the assembly from the brine well (large plastic tube)? Look at the air check to see if the words "Check Height" are on it. If so, that shoud be center of the grid plate. Can you post a pic or send it to me at affordablewtr@aol.com
    If he sets the Air Check at the grid, he never uses any of the heavier salt water below the Check Height line. His set up is correct. Salt grids usually have salt below the grid, in the water below the Check Height line on a Fleck 500 air check. The refill water does not have to rise up to or above the grid for proper salt dosing.
    It seems the softener is refilling and drawing brine water as it should so, IMO he has something else wrong as long as his water is not soft based on him actually doing a hardness test.
    He may have hardness break through and need to do two manual regenerations at the max lbs of salt of 15 lbs/cuft of resin back to back with no water use during or between them to bring the resin back to full capacity to stop the break through.
    Nov 2011
    TX
    I attached pictures of the valve assembly. Check height was not listed.
    • The valve rest on the bottom of the brine well.
    • The water level is 5 inches.
    • The grid height is 7 inches.
    Just to clarify, since I purchased the house over two months ago, there have been several regenerations, but no reduction in level of salt. I poured water into the brine well (gallon or so) and did two regenerations yesterday (added water manually both times) and the salt level dropped significantly. So it appears that either the water level needs to rise above the grid, or maybe the salt clumped and stopped dropping down past the grid.
    I dug my hands into the salt and could feel at least one small 1.5 inch hole, but could not tell if it was a true hole that allowed salt down or just an stamped indentation.
    Also, I don’t know the capacity of my system. The softening cylinder is chrome 54” high and 10” inch wide. Can you tell the size from this? Does the system size influence the brine refill time?
    Nov 2010
    Ocala, Florida
    And if it's the type of grid plate that does not allow salt below the plate level, then water will never touch the salt. I was taught that the check height was set at the plate height. This will insure salt meets water. In his case with the pickup being on the bottom, the water will not rise enough the contact the salt.
  1. Programming Fleck 7000 SXT
    By WolfB in forum Water Softener Forum, problems, installation and reviews
    Last Post: 05-23-2011, 04:53 AM
  2. Help Decode thsi Fleck 7000 Box Label
    By WCF in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-10-2011, 10:49 AM
  3. Fleck 7000 Problem
    By ArayT in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-03-2011, 11:04 PM
  4. Help Programming a Fleck 7000 SXT
    By batboy in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-03-2010, 06:43 PM
  5. fleck 7000 or clack ?? help
    By gerrythegreat in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-24-2006, 08:30 PM
