Results 1 to 7 of 7
Thread: Lowboy under countertop
    DIY Member justinae's Avatar
    Sep 2010
    Portland, OR
    Default Lowboy under countertop
    I've got a project converting a garage into a studio apartment. When the design was originally done we were going to use radiant heat so the architect never spec'd out a place for a hot water tank. That has now changed and we need to find a place for it. Right now the plan is to put it under the kitchen countertop. It's an outside corner next to an exterior wall so it won't be competing visually with other cabinets. Here are the tanks we're considering:
    AO Smith ECL-50
    Whirlpool E2F50LD045V
    American E62-50L-045DV
    Reliance 6 50 DOLS
    GE GE47S06AAG
    The American has the best specs at 31 5/8" tall by 24" in diameter. I'm concerned that there won't be enough room to make the connections to the supply lines. I'm assuming the dimensions are just for the tank and not the supply stubs.
    Anyone ever install one like this before?
    thanks,
    Justin
    Plumber jimbo's Avatar
    Electric water heaters could be condsidered a commodity, like pork bellies. Not much real difference from one to the next. Yes, the pipes almost always come off the top.
    Sep 2010
    Portland, OR
    Yeah AO makes one that comes out the sides but it's only 38 gallon. I think we'll go with the American just for being the shortest. We'll just have to have a 90 degree fitting coming right off the tank.
    What is the connection between radiant heat and a hot water tank? They serve two different purposes. One is for space heating, and the other is for "cleaning" uses.
    Sep 2010
    Portland, OR
    out here radiant floor heat is often connected into the potable water supply.
    quote;
    Exactly, therefore, it WOULD have needed a hot water heating unit of some kind, to supply BOTH needs.
    Sep 2010
    Portland, OR
    original design had gas on demand unit for both radiant and potable hot water. without the radiant floor, and subsequently gas, we need an electric water heater.
  1. Can't Find Lowboy Gas Water Heater
    By Marlis in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-10-2012, 05:58 PM
  2. LowBoy/Stubby Water Heater?
    By CubsFan in forum Water Heater Forum, Tanks
    Last Post: 03-30-2011, 05:39 AM
  3. need lowboy toilet replacement
    By rookie1234 in forum Toilet Forum discussions
    Last Post: 12-02-2009, 06:50 AM
  4. Bradford white lowboy
    By Cybermonkey in forum Water Heater Forum, Tanks
    Last Post: 04-07-2009, 07:38 AM
  5. Lowboy gas waterheaters.
    By hammerslammer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-30-2007, 09:54 PM
