Runs with Bison
Guys, this is really much to do about a very small problem. If you will get a bit more fiber in your diet which is a good idea anyway, most of the problem with skid marks will be taken care of. For the occasional times you over do on the diet and get a bit of marking, a quick brushing will take care of it. A brush in a decorative contain beside the toilet is pretty common in most bathrooms and certainly is not as offensive as a plunger. I believe I mentioned in an earlier response that I have had good success with just dropping 3 or 4 facial tissues in the bowl and flushing them.
As noted before it's not the below the water line stuff that is annoying (since CEFIONTECT dispatches it on the subsequent flush) it is the above water line stuff. Some of the same things that contribute to the roughage also make the above water line markes more likely.
Since we have Toto's there are no plungers anywhere near the bathrooms. They are stored away now. I still can't think of the toilet brush as anything but filthy--even after the clean up flushes. I want all of that water to stay in the bowl not in a decorative container beside the toilet. It stays in a utility space until time to do a thorough cleaning.
Haven't experimented with the manual coating, but I'll get around to it some time.
