Results 16 to 30 of 32
Thread: UTP Video Balun Pair for Cat5
  1. #16
    Dec 2009
    northfork, california
    So for video only this looks about right? http://www.mcmelectronics.com/produc...=prodCrossSell
    Seems odd they only use one wire of the cat5 cable.
  2. #17
    Mar 2011
    Houston, TX
    I think the first set was cheaper. You have to buy 2 of them, The other was a pair.
    Video is nothing more than an AC Signal with Various Frequencies,
    So You only need 2 wires (1 twisted pair). Leaves you more conductors for other things.
    You can power LEDs. IR lighting works best with B&W cameras.
  3. #18
    Dec 2009
    found some rca video to cat5 for 9 bucks each on amazonia, so went that route. Thanks.
  4. #19
    Dec 2009
    So now I don't know what I really have. Here is the product and I dont see any place for a cat5 cable or contacts.
    Nightmare.
    http://www.amazon.com/Composite-Vide...d_rhf_se_p_t_1
  5. #20
    Mar 2011
    Long Island, NY
    Quote Originally Posted by ballvalve View Post
    Nightmare.
    No description given other than it is for a cat 5 bezel (maybe a wall plate). It is possible that this connector has to be crimped to a Cat 5 cable (bulk cable) with an IDC tool
  6. #21
    Dec 2009
    Anyone know what passive keystone type over cat5 bezel means?
    There are two 1/6" holes on the rear, and no instructions of course. Perhaps those top tabs are to engage the cable, but everyone says they only use one wire of the cat 5 cable.....
  7. #22
    Mar 2011
    Houston, TX
    You use 1 twisted pair , 2 wires in the Cat5 wire and connect to the 2 connections.
    That gives you 3 more pairs for three more Cameras or other things.
    Just make sure that you connect the same Pair of wires on the other end of the wire.
    Pairs are 1 wire with a solid color then 1 wire with a white strip, and will be twisted together. 2 (Two) Wires.
  8. #23
    Dec 2009
    thanks. But i screwed up with these, as now I have to screw with cutting off the ends and stripping that little stuff.
    Now the dog cut a 200' cat5 cable. Can I splice these in the primitive method, cut strip and wind?
  9. #24
    Dec 2009
    repeat. maybe terrys update didnt do the job after all.
  10. #25
    Dec 2009
    I'll try again: can one splice cat5 with strip and wind, or must one use crimps and connectors?
  11. #26
    Mar 2011
    Houston, TX
    If you do splice, You need the keep the TP Twist as tight at possible.
    And you do need a RJ45 crimper to crimp the connectors properly.
  12. #27
    Mar 2011
    Long Island, NY
    CAT5 cables can be joined together easlily if they have the end (RJ45 Plugs) on them, with an RJ45 coupler.
    http://www.bhphotovideo.com/bnh/cont...=REG&A=details
    If the ends are plain wire ends, I dunno, but googling it comes up with:
    http://atlantatechpro.com/howtos/str.../88-splicecat5
  13. #28
    Mar 2011
    Houston, TX
    Nice BobLŪ.
    Just make sure that you put the heat shrink on, before making the splice.
    And if you do go the connector method, Don't use Crossovers for the RJ45 F-F adapter, Use Straight Thru adapters.
    If done correct the splice should be better. Just try to keep the same twist.
  14. #29
    Dec 2009
    Thanks. splice and solder would likely exceed the cost of 200' of cat5 which is down to about 10 bucks and less with connectors. Maybe a muzzle for the dog would be cheaper yet.
  15. #30
    DIY Junior Member balunman's Avatar
    Jan 2012
    israel
    Default balun with RCA
    The MuxLab 500021 and 500031 are composite video baluns with RCA on one end and Cat5 on the other.
    http://www.muxlab.com/products/ve_cc...lar_balun.html
    http://www.muxlab.com/products/ve_vg...ent_balun.html
  1. In-wall tanks to pair with Toto CT418FG
    By ChuckT in forum Toilet Forum discussions
    Last Post: 05-19-2011, 06:14 AM
  2. What does it take to be a plumber video
    By Terry in forum Drain Cleaning
    Last Post: 03-29-2010, 01:39 PM
  3. Video projector
    By synchronous in forum Electrical Forum discussion & Blog
    Last Post: 12-27-2008, 09:49 AM
  4. DWV Design Video
    By Nate R in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-26-2008, 05:16 PM
  5. drainage video
    By molo in forum Remodel Forum & Blog
    Last Post: 08-11-2007, 05:40 PM
