Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: UTP Video Balun Pair for Cat5
    Mar 2011
    Houston, TX
    Default UTP Video Balun Pair for Cat5
    I found this Balun Pair That does Color Video / Audio and Power using Cat5 Cable.
    http://www.amazon.com/LTS-LTA1010-Pa.../dp/B001HBP9ZC
    The Price is Right and the Quality is Good, Well They Work Fine.
    DonL
    Don't pay someone to do a job fast, when you can do a half-fast job yourself.
    Mar 2011
    Long Island, NY
    Nice; I've been using shielded video cables with BNC connectors directly from DVR to cameras so far
    Mar 2011
    Houston, TX
    Quote Originally Posted by BobL43 View Post
    Coax is nice, At least you don't have cross-talk to deal with.
    The only problem with using wire, Is lightning protection.
    Sometimes Wireless pays off just because of the Electrical Isolation that you get.
    Fiber also works great, You can't get much more Isolated than that. No ground loops to deal with either.
    Fiber should get cheaper, I look for more Fiber Optic stuff to be available at a reasonable price.
    Right now the twisted pair using Cat cable seems to be the choice for Video Security Systems.
    Dec 2009
    northfork, california
    Looks great, but why the power hookup? Do I need that power just for sending color video? And if yes, what transformer would work with that?
    Mar 2011
    Houston, TX
    You only need the power if your camera is located away from a usable power source.
    Or you could use it for Battery Backup Power.
    Dec 2009
    How about these? Miniature camera at one end and a vcr on the other...
    http://www.amazon.com/VideoSecu-Vide...4M/ref=lh_ni_t
    Mar 2011
    Houston, TX
    Them should work also.
    They are about the same as the other pair, but the other pair were the same on both ends.
    Either should work if you have the correct Male/Female connections.
    Dec 2009
    The connections are what I call 'rca' the old vcr type yellow, red [round] - and I have male-female adapters. is that what these are made for?
    Not much of of cable guy as you see.
    Mar 2011
    Long Island, NY
    yes, the picture on the right with that middle plug is the RCA type used on VCRs and also on TV's
    Mar 2011
    Houston, TX
    The audio is RCA connectors and the Video is BNC.
    You may need BNC to RCA adapters if your video camera is RCA.
    Dec 2009
    Thanks, which do I need, the male or female BNC to Rca adapter?
    http://www.homesecuritystore.com/nse...ca%20connector
    Whats with the BNC? Why cant I find a balun with rca inlets?
    And finally, I hope, whats the dif in cat5 and cat6 cable? they seem to be about the same cost; , are they interchangeable with simply higher speeds on the 6?
    Mar 2011
    Long Island, NY
    http://www.homesecuritystore.com/nse... rca connector
    I knew the CAT 6 was for higher sppeds like for my Gigabit router and LAN cards, but honestly, I did not know the difference in construction, so here is the answer: it has a longitudinal seperator as described here:
    http://cableorganizer.com/articles/cat5-cat5e-cat6.htm
    Mar 2011
    Houston, TX
    You will need one of each of those connectors.
    The BNC is a 75 ohm connection.
    Make sure your that your camera is 75 ohm or close.
    Normally Cat6 uses a slightly larger copper conductor.
    I would use Cat5e or Cat6, whatever you can get the best deal on, With connectors installed, unless you have a RJ45 Crimp tool.
    Dec 2009
    Thanks - The camera is a 6 year old pinhole type so I have no idea of its ohm rating.
    Anyone hear of a balun with rca leads? Do the new cameras only use the BNC?
    Mar 2011
    Houston, TX
    Yes they do make them
    http://www.mcmelectronics.com/product/50-7730
    But they are much more money.
    The Video is BNC or RCA and the Audio is RCA on the new ones. They come in both flavors.
  1. In-wall tanks to pair with Toto CT418FG
    By ChuckT in forum Toilet Forum discussions
    Last Post: 05-19-2011, 06:14 AM
  2. What does it take to be a plumber video
    By Terry in forum Drain Cleaning
    Last Post: 03-29-2010, 01:39 PM
  3. Video projector
    By synchronous in forum Electrical Forum discussion & Blog
    Last Post: 12-27-2008, 09:49 AM
  4. DWV Design Video
    By Nate R in forum Plumbing Forum Discussion & Blog
    Last Post: 01-26-2008, 05:16 PM
  5. drainage video
    By molo in forum Remodel Forum & Blog
    Last Post: 08-11-2007, 05:40 PM
