Thread: pressure switch wiring please help
    DIY Junior Member brenjake's Avatar
    Nov 2011
    cincinnati oh
    Default pressure switch wiring please help
    Hello I am trying to figure out how to wire a grundfos pump to the pressure switch. I have a 220 circuit red black and white with ground. The grundfos has three black wires and a green/yellow wire {ground?] Can you tell me what wire goes where? I have a square -D pressure switch mounted . I assume that the high voltage is the 220v diagram and the jumper bars Name:  DSCN0824.jpg
Size:  40.8 KBName:  DSCN0826.jpg
Size:  36.5 KB are in place as per diagram. So from the pump the L1 which is U1 on the diagram goes to L1 on the pressure switch ? And the L2 from the pump whish is V1 goes to the L2 on the pressure switch? Where does the L3 orW1 from the pump go to? Thanks for any help. Any kind of schematic would be a great help.
    Jan 2008
    You have a 3-wire pump, it must be connected to a control box which is matched to the pump motor. On a 3-wire pump the pressure switch and the pump are wired through the control box.
    Only a two-wire pump can be wired directly to a pressure switch.
    Dec 2009
    northfork, california
    But if you have three blacks coming out of the well, you have some careful ohmmeter work to do in order decipher what wire is which.
  1. wiring 220V Stenner pump to pressure switch
    By Flipperman2a2w in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-28-2011, 07:29 AM
  2. 3-way switch wiring
    By sucosam in forum Electrical Forum discussion & Blog
    Last Post: 10-14-2009, 05:48 AM
  3. Wiring Help for 2 Outlets (One on a Switch)
    By molo in forum Electrical Forum discussion & Blog
    Last Post: 09-28-2009, 05:12 PM
  4. wiring a three way switch....
    By rtstephn in forum Electrical Forum discussion & Blog
    Last Post: 06-14-2008, 09:23 PM
  5. wiring 2 way switch
    By zajnbou in forum Electrical Forum discussion & Blog
    Last Post: 12-24-2007, 07:22 PM
