Results 1 to 4 of 4
Thread: Kenmore water softner not drawing brine
    DIY Junior Member SHP's Avatar
    Nov 2011
    Maryland
    Default Kenmore water softner not drawing brine
    I have a Kenmore Elite water softner and it is not drawing brine. I have cleaned the venturi and gave it an extra back flush. Does anyone know what else I can do?
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    If the drain flow control is blocked the unit will not draw. Also the rotor, rotor seal or figure 8 o ring can cause it not to draw. If the venturi gasket has a lot of impression from the venturi, the draw will be chocked down. The unit comes with a flow control in the venturi. Remove it and check to see if you have a draw. Place unit on bypass. Advance it to a draw cycle and disconnect the brine line from the valve. Put the unit in service and check for a draw. If you have a draw and than lose it, the drain is restricted.
    Nov 2010
    Maine
    there is a link here somewhere to kenmore's equipment or you can slog around their site till you find it. It's very useful but..Mialynette has steered you in the right direction. You can find the break down of kenmore's site though
    Nov 2010
    Ocala, Florida
    http://www.kenmorewater.com/website/.../ts_index.html
    Here is the link for that site. It show how the systems works.
  1. Kenmore Brine Tank Delaminating
    By dave in WI in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-06-2012, 09:18 AM
  2. Kenmore no brine draw
    By Cruisinfanatic in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-30-2012, 09:17 PM
  3. smartwater not drawing brine
    By rightlane in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-28-2010, 06:40 PM
  4. Kenmore water softner: Water going in drain pipe continuously
    By gagan in forum Water Softener Forum, problems, installation and reviews
    Last Post: 01-21-2010, 12:34 PM
  5. Culligan mark 100 water softner water flowing to brine line all the time
    By seahawk99ca in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-27-2007, 09:35 AM
