Results 1 to 5 of 5
Thread: Pumptrol 9013FSG 2 Switch Problems
    DIY Junior Member MNavarette's Avatar
    Nov 2011
    Tomball, TX
    Default Pumptrol 9013FSG 2 Switch Problems
    The pump on my well does not kick in automatically. While I was trying to figure out what was wrong with the control system, I tapped on the Pumptrol switch and which turned on the well filling the tank with water. The Pumptrol turned off when it reached it's max setting; however, it does not turn on when even when pressure reaches 0. To start pump once again the Pumptrol needs to be tapped. Does this switch need to be replaced?
    Dec 2009
    northfork, california
    If its not a loose wire and you dont want to sleep in the pump house: yes.
    Feb 2011
    NW Ontario, Canada
    Just get your significant other to tap it for you. When that no longer works, take the cover off it and wiggle the pressure plate.
    Moderator valveman's Avatar
    Mar 2006
    It maybe that the nipple connecting it to the water line is clogged.
    Feb 2011
    NW Ontario, Canada
    My apology for the ascerbic reply. It is a $10 part, $20 tops... so swapping it out is a no brainer. Mineral builds up under the diaphragm preventing it from closing.
  1. Pressure switch problems ,,,,,I think
    By cajunguy1947 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-16-2010, 07:20 AM
  2. 4 way switch problems
    By cathead in forum Electrical Forum discussion & Blog
    Last Post: 07-13-2008, 09:38 AM
  3. Washing Machine triggers endless cycling of Pumptrol Pressure Switch
    By Zachrey in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-21-2008, 08:10 PM
  4. Pumptrol Switch Step by Step Replacement
    By fromjusttheking in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-06-2006, 05:25 PM
  5. Pumptrol Pessure switch rapidly cuts in/out
    By JWPH in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-29-2005, 02:36 AM
