Results 1 to 1 of 1
Thread: Options in replacing a drum trap under tub
    DIY Junior Member dave123's Avatar
    Nov 2011
    Western PA
    Default Options in replacing a drum trap under tub
    I had to remove an old copper drum trap, which was leaking, from beneath the tub in a bathroom. Was installed in 1951. A pic is here:
    You can see the area where the trap was removed, as well as the threaded copper tee coming from the tub, and the vent stack disappearing above.
    The trap had almost no piping on either side, and only a small amount of pipe was left to try to desolder from the upper tee. No amount of heating with a MAPP would free it. Inside it feels very corroded, and that might be the real problem.
    So I'm thinking I have no choice but to remove the wye, the 45, the 90, and the upper tee, and replace all with pvc. Biggest problem there is tying back into the vent, which lies flat in a corner, and impossible to get to from below, requiring making an opening in the plaster wall of the floor above.
    But wanted to see what those with more experience think, or if there might be some easier option I'm overlooking.
    Thanks.
  1. Bath P-Trap Pipe Options
    By gth1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-02-2011, 02:37 PM
  2. Options for a misaligned p-trap
    By exeunt in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-12-2010, 04:46 PM
  3. Adding shower to Laundry Trap
    By jgrove in forum Remodel Forum & Blog
    Last Post: 01-15-2008, 04:39 PM
  4. Adding a Trap to Existing Drain
    By adamells in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-12-2006, 02:38 PM
  5. Adding Utility Sink - Trap Height Question
    By kucharskimb in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-13-2005, 08:57 AM
