Thread: 4" Plastic Tube in Brine Tank Cracked
    DIY Senior Member TJanak's Avatar
    Sep 2009
    South TX
    Default 4" Plastic Tube in Brine Tank Cracked
    The vertical 4" plastic tube that has the float, etc. inside it has cracked at the bottom. The cracks begin from the uppermost slit in the tube and looks like they were caused by the salt grid being pretty tight around the tube and the weakness caused by those slits.
    I guess I need to replace it, but need to know where to get one.
    I thought about using schedule 20 pvc in 4" but the OD is too large. Maybe there is a 4" OD pvc tubing? The stuff that's in the tank currently seems pretty brittle.
    Travis
    When I need a precise measurement of something I often use the highly technical method of eyeballing it.
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    I could sell you one for around $10.00. Send me an e-mail at affordablewtr@aol.com
    Sep 2009
    South TX
    Thanks.
    Travis
    Travis
  1. Clear plastic tube from wash tub - what is it for?
    By gonzozen55 in forum Plumbing Forum Discussion & Blog
    Last Post: 08-23-2009, 06:25 AM
  2. Plastic tube pipe leak at clamp
    By bmerta in forum Plumbing Forum Discussion & Blog
    Last Post: 11-13-2008, 10:34 PM
  3. Replacing plastic dip tube, almost no clearance
    By zhomes in forum Plumbing Forum Discussion & Blog
    Last Post: 10-26-2008, 07:04 AM
  4. plastic faucet tube
    By christoff in forum Plumbing Forum Discussion & Blog
    Last Post: 10-22-2008, 08:16 PM
  5. Plastic Tube plumbing
    By Aubreyff in forum Plumbing Forum Discussion & Blog
    Last Post: 08-28-2007, 05:51 PM
