This is what I would like to do.
Build a box 4' X 8' with with copper tubing and glass for the collector on the roof coming into the shop with 3/8" tube coiled around a 30 gal water tank to heat the tank.
Using the water in the tank to heat the shop going threw 2 heat exchangers with fans behind each.
Both will have a thermostat, one on the roof to shut off the pump when temp. gets low and the other in the shop to regulate the shop temp.
The shop is 24' X 40' the temp. here gets a low of about 30 degrees (in Tn.)
What I need to know is will this work?
Pump GPM?
Size of collector?
Size of shop heat exchangers to heat shop?
Thanks for any help
Semon
Pump GPM?
Size of collector?
Thanks for any help
Semon
