Results 1 to 4 of 4
Thread: solaia cast iron boiler (3 pass) vs Burnham MPO series (3 pass) boiler both oil fired
    DIY Junior Member greyhound1's Avatar
    Jul 2009
    Pennsylvania
    Default solaia cast iron boiler (3 pass) vs Burnham MPO series (3 pass) boiler both oil fired
    Greetings: I am a residential homeowner and I intend to update my oil fired boiler with either a Solaia cast iron 3 pass system (firing rate of .75) or a Burnham MPO series 3 pass system (firing rate of .80). Both will be vented through my chimney (to be relined through a reputable chimney relining company in my area). I have separate bids from two plumbers: one is my oil company (Solaia) and the other is from a reputable plumber (Burnham) who has done several jobs for me, with which I have been satisfied. Both include Becket burners. The Solaia bid has a 40 gallon Lochinvar Squire indirect hot water storage tank, while the Burnham bid has a Burnham 40 gallon indirect hot water storage tank. Assuming that the bids are comparable in price, which do you think is the better system? Also, I read a competing online plumber's rating system that gave Solaia a 3 out of 5; the Burnham a 1 out of 5 and a Trane 3 pass system a 5 out of 5. Should I investigate the Trane (with sound blanket) or are the Solaia and Burnham systems good, efficient, quiet and reliable? This can get very confusing and any help would be appreciated. Any problems encountered with the systems? Any positive or negative experiences would be helpful. Terry, if you have a moment, I would appreciate your input as well!
    Thank you in advance.
    Greyhound1
    Nov 2010
    Maine
    I think they are both crap and would go with a Buderus or a Viessman
    Jul 2009
    Pennsylvania
    Tom Sawyer: Although I respect your opinion, could you be more specific as to why you do not like either brand or type of boiler?
    Thank you. Greyhound1
    Nov 2010
    Maine
    Burnham has been around a long time and when I look back on the boilers of the past, that had the most service issues, burnham has to be close to the top of the list. That said, and to be fair I have not installed a Burnham in over 30 years though I do work on a bunch of them. Maybe the MPO is good, I really shouldn't have made that statement but I have and always will have a dislike for anything Burnham. As for the Solaria, It's a nice piece of equipment but I worry about getting warranty work or replacement on the unit should it be needed. Make sure the dealer is reputable and has been in business for awhile
  1. gas fired boiler help
    By chuckbeland in forum Boiler Forum
    Last Post: 09-20-2011, 10:55 AM
  2. burnham-iq boiler
    By phaedrus123 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-10-2011, 03:03 PM
  3. Replies: 2
    Last Post: 04-03-2011, 06:39 PM
  4. Burnham V84 boiler
    By technogirl74 in forum Boiler Forum
    Last Post: 12-10-2010, 05:23 AM
  5. weill mcclain boiler, cast iron baseboard
    By mlbauer in forum Boiler Forum
    Last Post: 04-07-2009, 11:23 AM
