Thread: Water softener drain
    DIY Member mar3232's Avatar
    Oct 2011
    Indiana
    Default Water softener drain
    I have a Whirpool water softener and was wondering about the small drain hose on it (the one that uses a pump). Right now it has some copper pipe running lord knows where to drain it.
    I have a vertical 1 1/2 " PVC pipe that I use for my washing machine rubber hose drain.
    Can I use this pipe for the water softener drain also? Or would that be a possible problem of that water getting back into the washer some how?
    The water softener is right next to the washer and hence, the pvc drain pipe so it sure would be handy.
    If that's a no-no, I also have a utility sink close by, I suppose I could use that?
    THANK YOU.
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    It would be ok to run the drain line into the washer drain. There is a devise made for washer drain that provides an air gap. Local plumbing may require one.
    If you use the sink, and stop the drain line about an inch above the rim, that's your air gap (twice the size of the drain line) and you don't have to buy one or deal with using one in a washer drain pipe.
    Just make sure no one ever leaves the drain plug in the sink. I would remove it from the sink area so that can't happen and some plugs the drain and the softener overflows the sink some 2:00 AM.
    Oct 2011
    Indiana
    Thanks much.
  1. New drain for water softener
    By cacher_chick in forum Plumbing Forum Discussion & Blog
    Last Post: 12-24-2009, 01:49 PM
  2. New water softener - no drain
    By beanie376 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 12-10-2009, 10:01 PM
  3. Water Softener Drain
    By rdgallo in forum Plumbing Forum Discussion & Blog
    Last Post: 12-08-2008, 03:05 PM
  4. water softener drain
    By Leemonster in forum Plumbing Forum Discussion & Blog
    Last Post: 01-21-2006, 07:46 AM
  5. Water Softener Drain
    By hdtocell in forum Plumbing Forum Discussion & Blog
    Last Post: 02-14-2005, 11:29 AM
