Results 1 to 2 of 2
Thread: Manual Thermostat
    Default Manual Thermostat
    I have one small bedroom with radiant ceiling heat that does not seem to be working. The thermostat is a manual type 240 volt. I am wondering if the thermostat is bad and how I should check it. I have some electrical knowledge and test meters but not sure about testing a manual thermostat. I have not read alot of info about radiant ceiling heat troubleshooting. I am guessing that if the thermostat is not bad that the heating elements are bad and probably would have to go with baseboard heat. Thanks for your time.
    Plumber jimbo's Avatar
    You would have 240 volts across the two input wires, and 240 across the two output wires when the stat calls for heat. Probably you should not be messing around with 240 volts.
  1. Takagi TK-Jr Service Manual
    By jim7 in forum Tankless Water Heater Forum
    Last Post: 04-14-2011, 02:55 PM
  2. Converting a manual switch heating zone to a thermostat heating zone
    By breilly629 in forum HVAC Heating & Cooling
    Last Post: 03-12-2010, 01:04 PM
  3. Electric vs Manual Skylights
    By yds in forum Remodel Forum & Blog
    Last Post: 02-04-2010, 03:02 PM
  4. Manual J Does it sound correct
    By weather777 in forum HVAC Heating & Cooling
    Last Post: 11-03-2008, 09:10 PM
  5. Bosch DLX Dishwasher manual
    By connolly14620 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-12-2006, 01:04 PM
