Results 1 to 2 of 2
Thread: Tempering domestic water from wood heated tank
    DIY Junior Member Commonground's Avatar
    Feb 2011
    NS
    Default Tempering domestic water from wood heated tank
    I hope this is the right forum for my question:
    I heat my water with a wood stove just installed this year. The stove is located on the first floor, the 180 l tank just above it on the second floor. The water gets too hot for safe use at the taps. The winter has not started yet and I already have had 75C at the taps.
    I would like to know my options to avoid being scalded: tempering valve, mixing valve, temperature limiting valve at the point of use, one lever faucet, etc.
    I have 3 taps: a one lever faucet each at the kitchen sink and at the tub and a 2 handle faucet at the bathroom basin.
    The latter is where the problem is more acute as it is very difficult to adjust, especially because of the long run of pipe between the tank and the tap.
    Feb 2011
    NW Ontario, Canada
    They make mixing/tempering valves both for POU and at the tank. Why not also sink some of the surplus heat to heat part of the home? You could put in radiant floor heat or a radiator.
  1. Replies: 3
    Last Post: 02-06-2011, 01:33 PM
  2. Do I need expansion tank on domestic side of new HW heater?
    By staceyneil in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-06-2011, 11:20 AM
  3. Tankless vs Tank for Heating & Domestic Use
    By Canada_Dave in forum Tankless Water Heater Forum
    Last Post: 04-16-2009, 07:11 AM
  4. Tempering tank before electric water heater?
    By Scuba_Dave in forum Water Heater Forum, Tanks
    Last Post: 02-26-2009, 02:41 PM
  5. Source for tempering tank
    By RayP in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-21-2009, 03:10 PM
