The problem there is that the current drain does not have a vertical drop before going to the pipe in the wall and your proposed change with a long vertical drop could result in the trap being siphoned (since the vent would begin at the new connection point in the basement). As a DIYer who did not have to deal with an inspector, I might work around that siphon possibility by using 2" pipe to do what you are considering ...
... but the pros would likely blast me if I actually suggested that since it would likely never get past an inspector.
