Results 1 to 7 of 7
Thread: Aprilaire 600A won't turn on
Hybrid View
    DIY Junior Member mortal798's Avatar
    May 2011
    Pinckney, MI
    Default Aprilaire 600A won't turn on
    Hi everybody,
    I have an Aprilaire 600A, and just like the title says - it won't turn on. I have 24vAC at the 'R' and 'C' terminals in the controller. The water solenoid is hooked up to 'H' terminals. The outdoor temp sensor is hooked up to 'ODT.' And the unit is set up to use the call for heat from the t-stat to detect blower operation, so 'W/G' on the Aprilaire controller is hooked up to 'W' on the furnace board and 'Cf' on the controller is hooked up to Common on the furnace.
    Does it sound like my connections are correct? It won't even light up in 'Test/Reset' mode. Any ideas? Thanks in advance!
    May 2011
    Pinckney, MI
    Oh yeah, just another piece of info - it doesn't work with the manual resistor either...
    Mar 2011
    Houston, TX
    Is that a new install ?
    Did it ever work ?
    The solonoids don't last forever...you can just replace that, if it's the problem. If it has 24vac across the input to the solonoid, but it hasn't turned on, it's probably that.
    May 2011
    Pinckney, MI
    Did it ever work ?
    It used to work, I turned it off for the summer. Then I removed the old furnace and replaced it. Once I reconnected the 600A, it wouldn't turn on. I have 24vAC at the controller, but the display doesn't light up - and it won't even go into test mode. I think I may have a bad controller.
    The furnace works like a million bucks, just that d#$* humidifier won't come on.
    Mar 2011
    Houston, TX
    Quote Originally Posted by mortal798 View Post
    Hi everybody,
    The 2 H output terminals should have the 24VAC always-on transformer output winding is series with the solenoid,
    connected to them.
    Measuring from terminal H - H You should see 24VAC when the unit is not calling for humidity.
    May 2011
    Pinckney, MI
    connected to them.
    Yes, and when the solenoid comes on all the voltage should drop. The solenoid coming on isn't the problem (well, it may be a problem later...), the controller doesn't come on to tell the solenoid to come on. The controller doesn't even light up in test mode.
  1. Aprilaire 1710A Stand Alone Dehumidifier
    By mrmichaeljmoore in forum HVAC Heating & Cooling
    Last Post: 07-29-2010, 08:48 AM
  2. can a multi-turn shutoff turn itself on?
    By dekelly in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-21-2009, 07:26 AM
  3. aprilaire humidifier
    By 30all in forum HVAC Heating & Cooling
    Last Post: 03-08-2009, 06:04 PM
  4. Aprilaire 760 humidifier
    By Ronn in forum HVAC Heating & Cooling
    Last Post: 02-02-2008, 02:38 PM
  5. how far to turn sink, tub, or toilet shutoff valves to turn on water
    By ydelamater in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-12-2007, 06:28 PM
