Thread: mansfield 35 flush valve or seal leak
    DIY Junior Member mschloss's Avatar
    Oct 2011
    New Hampshire
    Default mansfield 35 flush valve or seal leak
    I recently replaced the flush seal (the red one) and the fill valve for a Mansfield 35 toilet that is 18 years old. After the tank filled I shut the water supply off. Even though I couldn't hear it refilling or leaking, the tank is empty when I check it the following morning. Should I install a new Mansfield tower style flush valve or can I replace it with a Fluidmaster 507A or 507C flush valve? There doesn't seem to be a good seal with the flush seal. Thanks for your help.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by mschloss View Post
    ...the tank is empty when I check it the following morning.
    Maybe you sleepwalk? The textbook test is to put some dye in the tank.
    since I have not had that problem with a Mansfield toilet, I have to assume you did NOT position the seal at the bottom of the tower properly, or your seal is warped or otherwise defective.
    Oct 2011
    New Hampshire
    I made sure the seal was on correctly - placed on the upper ring. I thought that maybe the overflow tube was siphoning the tank so I pulled the tube out of the overflow last night. The tank was empty in the morning. I guess I'll buy another seal and try it again. If that doesn't work I'll replace the flush valve. If I do replace the flush valve would you recommend replacing with the same Mansfield tower flush valve or installing a different brand with a flapper instead? Thanks for the help.
  1. Mansfield 210 flush valve
    By Joatmon in forum Toilet Forum discussions
    Last Post: 12-15-2009, 06:51 PM
  2. Mansfield 180 flush valve
    By azgal in forum Toilet Forum discussions
    Last Post: 06-17-2009, 09:43 AM
  3. Leak from Flush seal
    By ronmax999 in forum Toilet Forum discussions
    Last Post: 11-16-2008, 06:49 AM
  4. Mansfield 160 Flush Valve Seal
    By dzmfntz in forum Toilet Forum discussions
    Last Post: 01-21-2008, 07:17 AM
  5. New Mansfield flush valve seal
    By punkyb76 in forum Toilet Forum discussions
    Last Post: 07-08-2007, 07:15 AM
