Results 1 to 3 of 3
Thread: Schedule 40 pvc through basement concrete slab
Hybrid View
    DIY Junior Member buckaroo1234's Avatar
    Oct 2011
    iowa
    Default Schedule 40 pvc through basement concrete slab
    Hello eveyone. I'm currently remodeling a basement bathroom. I'm installing a 48 x 34 Sterling
    shower receptor on a concrete slab and have a few questions.
    1. Good drain to use - was thinking about the Oatey brass drain that clamps around the pvc pipe in case of future maintance issues.
    2. Should the schedule 40 pipe be sleeved where it goes through the slab or should i make sure to leave a small area around the bottom of the drain void of concrete when i set the drain. If sleeved what is the proper material to use?
    Other notes are that i have positioned the p trap in the proper location under the slab. The plan is to use schedule 40 for the riser and connect to the receptor pan. The receptor drain cutout rests directly on the concrete - ie there is no space between the bottom of the drain cutout and the floor. Thanks for all replys.
    Don
    Aug 2009
    South*East
    I think you will find that the strainer actually extends below the shower floor. You will need a spacer around the PVC for the strainer. You could just rap the pipe with cardboard several times to accomplish this.
    John
    Oct 2011
    iowa
    Thanks John.
    Don
  1. two capped copper pipes protruding from concrete slab in basement
    By Pickngrin in forum Plumbing Forum Discussion & Blog
    Last Post: 02-21-2011, 11:16 AM
  2. Drilling concrete slab
    By Ian Gills in forum Remodel Forum & Blog
    Last Post: 01-18-2009, 07:32 AM
  3. Schedule 40 PVC vs. Schedule 40 Foam Core
    By ROSSBYINGTON in forum Plumbing Forum Discussion & Blog
    Last Post: 04-10-2008, 03:48 PM
  4. Condo on a concrete slab
    By mtnbiker3000 in forum Toilet Forum discussions
    Last Post: 10-05-2006, 11:09 AM
  5. Schedule 40 PVC vs. Schedule 40 Foam Core PVC
    By Fran in forum Plumbing Forum Discussion & Blog
    Last Post: 02-09-2005, 09:44 AM
