Results 1 to 9 of 9
Thread: New Toilet/Bathroom Drain Trouble
    DIY Junior Member the.timmer's Avatar
    Oct 2011
    Michigan
    Default New Toilet/Bathroom Drain Trouble
    Over the weekend we installed a new bathroom to have one on the 2nd floor. Ran out of time before being able to install everything, but were able to get the tub connected to the drain and set the toilet. Left the sink drain sticking up about 6" above the subfloor for now. When it came time to test the toilet, it doesn't drain. When you flush it, the bowl fills, but nothing goes down.
    I pulled the toilet, ran a line through the bowl out the bottom of the toilet, it went through - no problem. Took the toilet outside, filled the tank and flushed it - no problem. I then set the toilet again and it flushed somewhat, but was inconsistent. Ended up finding that the wax ring was no longer making a seal and air & some water was being pushed out the side/bottom of the toilet but most of it went down the drain. Went and got a new wax ring which sealed it, but also put me back at my original problem. The toilet will flush but won't drain.
    I'll post a picture of it later, but the drain first connects into the rest of the drain system from the basement at a 4" pvc, goes up through the first floor to the second and then reduces to 3". It then goes to a Y connection and splits off to the toilet, and the other side goes to the sink, then to the tub.
    The tub drains fine, and when pouring water from a bucket through the toilet flange, it seems to drain fine. Toilet is a Kohler Wellworth Classic, which is what we have in the first floor bathroom. We were thinking it may be a vent problem, but the sink drain that is 2' upstream from the toilet is wide open, and I've tried drilling a 1 1/2" hole in the drain, a few feet downstream from the toilet but it still has the same result.
    DIY Junior Member BizzyBeePlumbing's Avatar
    Aug 2011
    Raleigh,Nc
    do you have any vents on this new bathroom you installed? was it inspected? did a plumber complete the work? when you flush the toilet, does the water come all the way to the rim? swirl? is the closet bend holding water or the drain? did the toilet come from home depot? if the drain is done properly, then the toilet is defective. There isnt a test plug anywhere in the line is there? the line could be partially stopped up, taking water from a bucket but not from a toilet flushing.
    Oct 2011
    Michigan
    Think I've got it figured out. We weren't thinking about it when we roughed in the plumbing a year ago and put a trap on the toilet drain. Now if only we didn't already lay the subfloor, thinset and durock... /cry
    This should be an episode on Renovation Realities.
    Feb 2005
    Omaha, NE
    Quote Originally Posted by the.timmer View Post
    That could do it!
    Where did you get the idea of putting a trap in a toilet drain?
    Oct 2011
    Michigan
    Quote Originally Posted by SteveW View Post
    That could do it!
    My brother wasn't thinking. He's a builder who dabbles in everything. Fortunately he's not the type to make mistakes twice, but unfortunately my house was the one he made it on. Oh well, live and learn.
    Aug 2009
    South*East
    Sounds like your brother is a accident looking for a place to happen.
    John
    Mar 2011
    Long Island, NY
    Sorry, but I can't resist. I should be ashamed to make fun of your dilemna, but we all get in to them sooner or later.
    http://www.google.com/products/catal...ed=0CFoQ8wIwAA#
    Oct 2011
    Michigan
    Quote Originally Posted by johnjh2o1 View Post
    John
    He does good work, but only does plumbing work occasionally. Everyone makes dumb mistakes, even in their own field.
    Mar 2011
    Long Island, NY
    Yes of course, me included. At least you didn't tile it yet.
  1. Trouble with bathroom sink plumbing - s-shape???? Need help fast!
    By nole01 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-22-2010, 06:06 PM
  2. Trouble Replacing Bathroom Faucet
    By NewHomeGuy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-12-2010, 09:16 AM
  3. 1810 bathroom floor tile trouble
    By kdj in forum Remodel Forum & Blog
    Last Post: 04-06-2008, 08:48 AM
  4. New water main = bathroom trouble
    By bschafran in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-18-2007, 10:12 AM
  5. drain trouble
    By franko in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-29-2005, 05:35 AM
