Results 1 to 3 of 3
Thread: Reverse Osmosis or not
    DIY Junior Member Kai's Avatar
    Mar 2005
    Default Reverse Osmosis or not
    Hi All,
    After reading some old posts here, I have a new question. Should I use RO filter or not. My water is pretty good comparing to standard. It has little Nitrite, well bellow the safety limit, and little hard. No bacteria has been detected. I have installed softner to solve the hardness issue. My concern is that the water quality may vary due to rain or snow during a year. I cannot monitor the water constantly. So I think it may be make sense to install a RO system for dring water. I saw many information about the greatness of RO, from both manufacturer and third party. I also see some concerns here. Should I install my RO or return it?
    Thanks,
    Kai
    Plumber jimbo's Avatar
    Always remember that no filter, including RO, will fix water which is bacteriolgicvally unsafe.
    Lots of people put an RO on for their drinking water after a softener to remove the sodium.
    You need only test for Nitrate say every wet season or every 2-3 months. Most people do not need a RO. Even for added sodium due to a softener. The formula is 7.85 mg/l (roughly a quart) of added sodium per gpg of ion exchange. Usually a slice of white bread has more sodium in it... or a glass of skim milk, at 530 mg.
    There are drinking water filters for the removal of Nitrates. They use anion, Nitrate specific, resin. They cost much less to purchase and maintain than RO.
    Jimbo, agreed on the no RO and bacteria but there are ceramic POU filters for removal of bacteria from water. They are able to be cleaned with a stiff brush and reused.
    Gary
    Quality Water Associates
  1. New RO, Reverse osmosis
    By water solutions in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-21-2012, 12:50 PM
  2. Questions about Reverse osmosis
    By Primer in forum Water Softener Forum, problems, installation and reviews
    Last Post: 12-03-2011, 06:06 PM
  3. Reverse osmosis systems
    By lisao1958 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-18-2011, 08:11 AM
  4. Reverse Osmosis Distance
    By peterd in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-12-2008, 12:43 PM
  5. Help with reverse osmosis sytem
    By Girevik in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-24-2007, 07:59 AM
